Gahhhh! Idiot Garmi...
[Closed] Gahhhh! Idiot Garmin 800 question...
[#3584144]
I've bought an 800 with the 1:50,000 Garmin GB discoverer maps, but I live in Norn Irn and the maps don't cover here...
I dont fancy shelling out another £100 to Garmin for the Northern Ireland Maps alone, and I'd like to hang onto the GB maps for the odd trip to explore remote bits of GB by bike.
Is there a way of getting Northern Irish maps that will work on an Edge 800 but not from Garmin?
Thanks in advance, Andy.
Posted : 19/01/2012 3:32 pm
[url= http://talkytoaster.info/ukmaps.htm ]Try here[/url]
Posted : 19/01/2012 4:00 pm
Thank you David. I think I may be too dumb to do this, suddenly the £100 looks good value!
Posted : 19/01/2012 4:14 pm
http://singletrackworld.com/forum/topic/125k-os-maps-for-garmin-edge-800
Follow this link to my similar question. Mobile Altas Creator as described works and is dead easy !
Here's where to get it safely:
http://mobile-atlas-creator.en.softonic.com/
Posted : 19/01/2012 5:41 pm
andy: it is a really simple procedure.
0) remove your current SD card
1) Download [url= http://talkytoaster.info/111230-British-Isles+Contours-Routable-OS50tt-GMAPSUPP.zip ]THIS[/url]
2) Unzip it
3) copy the file GMAPSUPP.IMG to your GARMIN device (plug the Garmin in it should pop up as a disk drive) in the root directory
4) Run the installer in the ZIP file to install maps on your PC or Mac
If you get really scared the bloke will load it onto an SD card for you for £11
Posted : 19/01/2012 6:44 pm
Where do i find "the bloke"?
Posted : 19/01/2012 8:34 pm
http://talkytoaster.info/payment-faq.htm
If you've got an SD card though it really is simple.
I'd rename the *.img to something meaning full rather than GMAPSUPP.img as the edge supports multiple img file.
Copy the img onto the Garmin folder in the SD card and your done.
Maps are from OpenStreetMap so all above board
Posted : 19/01/2012 9:12 pm
Thats a 485meg file there, am i doing something wrong, or is it too big to just copy direct to garmin 800? mines says 105meg max size...
cheers
Posted : 19/01/2012 10:44 pm
DenDennis, you might need to delete one that is on there already. Also clean out the Activities file.
clowner, does the 800 allow you to select which map in this case? that could be pretty damned useful and I've not tried it
Posted : 19/01/2012 10:48 pm
Either here [url= http://talkytoaster.info/ ](the bloke)[/url], or in the Pint and Prostitute on Manchester Road
Posted : 19/01/2012 10:49 pm
DavidB I am forever in your debt. If you are ever in Belfast, there's a pint or two waiting here for you!
Posted : 20/01/2012 2:17 pm
DenDennis you are trying to copy onto the device directly and not the SD card.
The SD card on mine appears one drive letter up from the main unit.
If not already there you will need to create a Garmin directory to copy the .img file into
Posted : 20/01/2012 3:08 pm
DavidB yeah you can select which maps you want to have enabled.
It's under Wrench -> Settings -> Maps -> Select Map
In this menu all maps enabled on the device will be displayed and you can enable/disable them all individually.
Posted : 20/01/2012 3:18 pm
clowner -> get yourself to Belfast and have my free pint on me. I am such a dipstick to have missed that
Posted : 20/01/2012 5:42 pm
quick question for any garmin users with the openstreetmap map file linked above:
the map has loads of icons on, such as triangles for ped crossings, so many that the map becomes obliterated at certain zoom levels.
is there a way to turn the display of this stuff off, or does it require a different map file?
thanks in advance 😀
Posted : 20/02/2012 9:03 pm
