Full Cable Outer Ad...
[Closed] Full Cable Outer Adapters
[#4606016]
Been doing some bike hunting for a friend, and came across this:
Anyone know where I can get a similar adapter for running full cable outer on my gear lines on my Commencal meta? I'm fed-up with them filling up with water and the cables rusting inside.
Posted : 29/11/2012 12:17 pm
drill + five minutes.
Posted : 29/11/2012 12:20 pm
You'd be hard-pushed to get a drill that close.
Round needle file and about 10 mins... 🙂
Posted : 29/11/2012 12:22 pm
Or a few zip ties and stop worrying about it 😛
Posted : 29/11/2012 12:23 pm
these?
http://www.chainreactioncycles.com/Models.aspx?ModelID=28123
Posted : 29/11/2012 12:26 pm
I use a bunch of these shoe-gooed to my frame;
http://www.chainreactioncycles.com/Models.aspx?ModelID=19014
The problem with drilling your frame or anything along those lines is that it never holds the cable firmly as the hole will undoubtedly be bit too big, so the cable flaps around (unless you put zipties round the tubing).
Posted : 29/11/2012 12:27 pm
Here...
http://www.chainreactioncycles.com/Models.aspx?ModelID=34709
PaulD
Posted : 29/11/2012 12:29 pm
Thanks everyone.
I had already thought of that, bit reluctant to mod the frame though, don't want to risk damaging it, or reducing it's value further.
But it looks so messy!
these?
br />
Thanks! Those are spot on what I was thinking.
Not as elegant as the solution above, but look ideal for my plans of getting a dropper, although I'll probably just cable-tie that hose onto one of the others.
Thanks paul, one up on the other similar ones, just because they look better in Black.
Posted : 29/11/2012 12:34 pm
Why not run a set of mud snake or flying snake gear cables, or even the sealed gore ones?
Jay
Posted : 29/11/2012 12:44 pm
Magura do a similar one to the M-Part but is slightly tidier in that it's not adjustable. Okay for disc hoses but not secure/tight enough for gear cables. There may be cheaper places than the link below...
http://www.ebay.co.uk/itm/Magura-Brake-Hose-Guide-Hydraulic-cable-guide-brand-new-disc-brake-hayes-hope-/160928833290?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item25781b1f0a
Posted : 29/11/2012 12:47 pm
Thread a zip tie througha bit of old camelpack tubing or similar cut to about 2-3mm, round the frame/other hose/fork leg, then back through the bit of hose, arroudn the cable and do it up.
Cost's naff all and lasts forever.
Posted : 29/11/2012 1:20 pm
I have been looking at the Gore ones, but they are really quite expensive.
Posted : 29/11/2012 2:10 pm
