fsa megaexo - ht2 r...
[Closed] fsa megaexo - ht2 replacement?
 doh
[#3765789]
bb on my fsa gossamer cx megaexo chainset is dead can i replace it with shimano?
Posted : 12/03/2012 2:58 pm
Yes. I replaced the FSA bb on my son's cross with a 105 bb - half the cost and twice the lifespan!
Posted : 12/03/2012 3:09 pm
I wondered about doing it last Autumn when my FSA one on my Jake the Snake died - ended up buying another FSA but if Shimano fits will do that next time
Posted : 12/03/2012 3:11 pm
I fitted a Superstar into mine - half the cost and half the lifespan! Have now got a Hope.
Both the Hope and Superstar b/b were sold as shimano/ FSA compatible.
Posted : 12/03/2012 3:16 pm
 doh
cheers all. the fsa one died after a few hundred mainly road miles, total crap.
Posted : 12/03/2012 3:17 pm
Its Truvative ones that are not compatable if i recall, FSA/Shimano/Raceface/Hope are all interchangeable.
Raceface are made of cheese and are the worst performers in my experience.
Hope/King etc are too pricy i think so i've just stocked up the spares bin with 3 XTR ones from Rosebikes at £16.90 each. At that price you can't go far wrong? Basic Deore ones are less than £8 i think if you really want bargaintastic bits - you could put a new one in every month!!
Posted : 12/03/2012 3:41 pm
Top tip: you can extend the life of an FSA b/b by prising off the dust seals and packing it out with grease. That said, if it died that quickly, I'd see if your frame needs facing.
Posted : 12/03/2012 3:47 pm
Yup should be fine - I have to say my FSA MegaExo (with extra shell protection) is still going strong after 2 years - amazed really given their reputation!
I do service is say every 6 months esp if it gets any creaks.
I bought a hope bb for my FSA comet (megaexo) cranks and they dont fit! The FSA cranks seem to be fraction fatter than the h2 standard.
Posted : 12/03/2012 5:15 pm
My hope b/b fits fine on mine! I did have a problem during fitting - a seal came off the b/b when I extracted the drive side crank, and was hidden from view by the inner chainring and spider - which meant it didn't fit properly on first attempt. Maybe you have the same problem?
Posted : 12/03/2012 5:20 pm
yup. megaexo is ever so slightly larger on the drive side bearing, for no reason whatsoever other than they would like to lock you into their replacement BBs. I've got a set that I'm going to get turned down to the right size, but for the moment an occasional dolloping of grease seems to keep the BB alive.
Posted : 12/03/2012 5:25 pm
Home come my Hope fits my megaexo cranks? Did FSA change the design?
Posted : 12/03/2012 5:51 pm
I know that a mate had some old Mega exo cranks and would only fit his Hope BB with a mallet - Perhaps it depends on the year? Mine seem fine?
Posted : 12/03/2012 5:55 pm
There are a few variations of 'megaexo'. The comet cranks I have need a BB7000 BB (same as Afterburner/V-Drive/Moto-X cranks)
[url= http://www.bikeman.com/images/stories/RepairTechInfo/externalbbfitchart.pdf ]Heres [/url]a good compatibility list [pdf warning]
Posted : 12/03/2012 6:07 pm
The difference is only about 0.2mm, so depends on the model and BB. TBH, when my cranks need it, I'll probably just sandpaper them!
Posted : 12/03/2012 6:14 pm
