I have a set of the FSA afterburner and K-Force Light wheelsets. They can run 9mm and 15F 12x142R thru axles.
I've been trying to fit the rear wheel onto my 12x142 frame and can for the life of me get the axle thru the hub. Front is fine but the rear wont go.
The rear hub has a left side cap that converts from 9m to 12m. Without the cap the axle slides thru fine, if i slide just the cap onto the axle its also slides on fine, problem is when the cap is on the hub the axle refuses to slide thru easily.
I bought a new 12x142 maxle thinking mine was bent but i get the same issue.
Any one got this wheel set or have any advice? Its doing my head in!
Thanks,
Andy
I've emailed FSA support, lets see if anything comes back.
Its crazy to have £1.5K wheelset and not be able to use them, ive tried 2 different 12mm axles and neither work.
