Front Tyre Mud Guar...
[Closed] Front Tyre Mud Guard !
I,m in need of a front Mud Guard, Something sturdy and something not fabricated from a 4 Pint bottle of cow Juice, 🙄
I,ve just had a few days really sick ! Stomach ache cramps squits !
The day prior to my bout of bombay trots i did a ride where by i may have had a bit of shhep sh!t flick up and god knows why i ended up with it in my mouth ! not just once but about 3 times on various different sections !
And to add to the dilema i passed along a bridleway that had untold ammounts of fresh dollops of cow pat on and a pile of manure in the corner with the brown liquid seeping out !
I could explain the taste 😕 BARF !
So ive thought about front guard, i,m running a MAXXIS Minion 42a up front & its like chewing gum !
It flicks up all sorts.
Ive been on CRC and found a THE front guard which looks a bit MX stylie !
It looks more than up to the job.
Question is ! Has anybody got one and are they any good ?
Posted : 08/11/2010 4:35 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=31303 ]this[/url]
and
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=24478 ]this[/url]
job's a gud un
Posted : 08/11/2010 4:38 pm
I use the [url= http://www.muckynutz.com/index.php?route=product/category&path=24 ]mucknutz bender fender 2.0[/url] backed up with a down tube mounted crud catcher when needed. Works phenomenally well at stopping my 42a 2.35 minion from feeding me! It certainly works better than the RRP NeoGuard neoprene fork crown brace spanning one I had last winter as it stops more and doesn't dump the crud on your fork seals.
Posted : 08/11/2010 4:55 pm
If you travel your bike with the front wheel removed, I'd get an SKS shockblade or similar as the removal makes it fit in the car much better.
The THE looks similar to my Planet X, and is a pain in the arse for this reason.
Posted : 08/11/2010 4:57 pm
For some reason I keep thinking "codpiece" when i see these!
Posted : 08/11/2010 4:59 pm
got a THE version and it does the same job as the crud catcher.
works fine for me.
Posted : 08/11/2010 5:06 pm
I used the SKS Shockblade for the first time at the weekend and have nothing but praise for it. Did the job perfectly and cost a bit less than THE etc
Posted : 08/11/2010 5:48 pm
docrobster +1
this is the best way of beating mud
Posted : 08/11/2010 6:23 pm
I just bought a 30cm x 30cm piece of neoprene off ebay, thats 2 rapid racer style things for £5... thats more like it
Posted : 08/11/2010 6:26 pm
I've used a THE for years, I used them when I was racing DH and I still use one on the trail bike if it's a really shitty day. I'd recommend them without hesitation, I'd also recommend using a headlock with a 6mm tapped hole in the bottom to make installing and removing your THE easier
Posted : 08/11/2010 6:33 pm
1nten5e,
Thats what i wanted to hear
I have tapered forks with a 1.5 gaping hole in the bottom, do they come with relevant fittings ?
Posted : 08/11/2010 6:39 pm
 br
I use a Crud Front Fender, along with a Crud Catcher - its great and you can actually ride without glasses if you need to.
Posted : 08/11/2010 6:42 pm
santacrews, not sure about that, I have an old 'ed-lock' thats all alloy, got someone to turn a new bottom part for me, cos I've just gone tapered too
No worries if you know someone with a lathe....but probably would only cost a few quid at an engineering shop
Posted : 08/11/2010 6:52 pm
"do they come with relevant fittings?"
Yes but you will best put something grippy (even just masking tape)round the plastic expander so it gets a good grip.
Mine is two years old now and has a slight looseness in the QR fitting but nothing to worry about. If it gets bad I'll just silicon it in as I don't need the QR.
has anyone tried the Topeak defender M1? looks similar to the Shockblade but has flexible edges which might make it resist impacts, not that I ever crash... 😉
Posted : 15/11/2010 8:02 pm
old inner tube + 4 x zipties....strap tube from fork crown to stanchion brace, stops a lot of front wheel chuck off coming back in yer face
Posted : 15/11/2010 8:23 pm
 nuke
Another vote for the SKS Shockblade...works very well and would buy another without hesitation
Posted : 15/11/2010 8:35 pm
Haven't tried the other options, but the Fast Fender works really well.
Posted : 15/11/2010 8:40 pm
I've just bought a muckynutz thing, seems to rub on my stantions? I presume I've fitted it wrong?????
Posted : 15/11/2010 8:43 pm
+1 for the Crud Catcher and Fast Fender combo.
I was amazed how much difference the Fast Fender made this weekend, after using only a Crud Catcher for the last 17 years. It's ugly but it works.
Posted : 15/11/2010 8:47 pm
crud catcher and neo guard here. top job. i might think about a muckynutz instead of the neogaurd if i were buying again.
Posted : 15/11/2010 10:33 pm
Used both SKS Shockboard and Topeak, prefer SKS.... Topeak was ok but I snapped the front of the metal bracket
Posted : 15/11/2010 10:40 pm
THE are the way to go, ideally bolted into a star-fangled nut in the bottom of your steerer tube. Bit of a faff to remove, but likewise, don't fall off very easily (unlike the SKS and Topeak)
Posted : 15/11/2010 10:45 pm
