Had anyone got a suggestion for a clip on mudguard for the front of a Boardman CX Team?
It gets used for a local offroad CX ride as well as work commuting duties, so don't want to fit SKS bolt on guards. However, the down tube has a couple of cables (scuppering a Crud Catcher type thing) and the bottom of the fork doesn't have a hole to plug something into.
Any thoughts or suggestions. Many thanks
FTM
Too cheap not to buy:
http://www.muckynutz.com/index.php?route=product/product&path=49&product_id=151
On a CX bike?? ๐
On a CX bike??
Why not?
Will the Gut Fender not be fouled by the two downtube cables though?
I want the mudguards for commuting, but to whip them off easily when I'm out on the trails. Already got a read guard.
I should have realised, as I actually had one, that the Boardman CX has the cables, with no outers, on the underside of the downtube.
I think any guard that mounts in that position is probably a no go due to the cable routing.
It will take no more than a couple of minute to remove a front sks mudguard - is that too slow?
Edit - Oh, do you mean you you want to remove it when you're out and about?
