Front mech size for...
[Closed] Front mech size for an Alpine, and Lyriks
[#433406]
Anyone know the front mech size for a dialled Alpine? I have a 28.6/34.9, however it seems either slightly too small or miles too big.
Also anyone ridden one with Lyriks? and if so what was it like
Posted : 30/03/2009 10:49 am
It's a special size - some shims are supplied with the frame
Posted : 30/03/2009 10:51 am
arse, I got the frame 2nd hand and there weren't any shims.
Posted : 30/03/2009 10:58 am
It's about 30mm I think - you might be able to use one bigger shim and some Coke can?
Posted : 30/03/2009 10:59 am
yep might try that and some inner tube/coke can
Posted : 30/03/2009 11:03 am
Use 1 bigger and 1 smaller shimano shim, they will bend a bit but it will be fine.
ST has lyrics on his, goes down like a czech whore.
That is what I did.....and then I found the shims in the box afterwards.
Posted : 30/03/2009 11:10 am
Also anyone know if the ISCG mounts are 05 or not?
Posted : 30/03/2009 11:30 am
old ISCG
Posted : 30/03/2009 11:38 am
cheers 😉
Posted : 30/03/2009 11:41 am
Lyriks would be fine, but I dont think you need 160mm travel unless your riding in the alps
Posted : 30/03/2009 11:42 am
Thats what I am thinking, I have some 05 AM1's but as they are QR's they are a bit twangy but more than likely better suited for all round riding.
Posted : 30/03/2009 12:41 pm
 st
Saw this thread earlier but forgot my password to log on at work.
I've got Lyriks on my Alpine and they are ace. Mostly have it set to 140mm and it behave really well. Wound down to 120mm it's wrong, jack it up to 160mm for bigger descents and it absolutely flies.
Perfect fork to get the most out of that frame I reckon.
Posted : 30/03/2009 9:09 pm
