Front mech problems
[Closed] Front mech problems
[#2221153]
I fitted my front mech with new cables etc. when I replaced the cranks, rear mech and shifters but can't set it up properly. I can get it into the top to rings on the cranks but it's no where near getting into the small ring. Youtube videos don't help so what could be my problem?
cheers
Posted : 24/11/2010 10:44 pm
lower limit screw?
right spacers on the bb?
it is the right mech for the size teeth etc?
Posted : 24/11/2010 10:57 pm
What mech,what chainset, what BB? Some combinations are incompatible.
Posted : 24/11/2010 11:06 pm
as above. need to know what you took off and what youve fitted. but it will probably be down to adjusting the limit screws.
Posted : 24/11/2010 11:16 pm
Which model number front mech is it?
Posted : 24/11/2010 11:18 pm
 taka
his front mech is an xtr m961 and the cranks are xt m760 2 spacers on the driveside one on non-driveside
Posted : 24/11/2010 11:22 pm
did the mech come with instructions? im sure that the M961 is for a non compact (26/36/48 or similar) chainset, and the chainset you have is compact. if it is indeed for non compact (22/32/44 tooth), then it wont work cause its designed to work with a larger chainset. the instructions will clear that up. if the limit screws dont adjust enough, its the only thing i can think of.
Posted : 24/11/2010 11:51 pm
