Front boost convers...
[Closed] Front boost conversion
My new forks are boost so I've bought a convertor cap from hope to put in the non brake side of my pro2/4 hubs, mistakenly believing the wheel wouldn't need dishing.
But it does, 5mm.
Has anyone done this?
I can't help thinking the wheel would be significantly weakened by such an offset?
Would I be better off just forking out for the wheel?
Posted : 12/10/2017 1:24 pm
To plenty of wheels plenty of times.
It'll probably be stronger seeing as it's currently 'offset' over the brake mount and you're just moving it back over the flanges a bit.
No (well, maybe, but only if you're a mechanical clutz, the nipples are alloy or you're a princess who can detect a pea sized stiffness increase with fractionally wider flanges).
Just do it slowly, 1/4 turn on each of the DS spokes, then 1/4 off the NDS, and repeat until it's central in the fork. It's probably about one turn depending on spoke tension.
Posted : 12/10/2017 1:29 pm
I have. The wheel will need less dish so theoretically a little stronger.
Edit: Beaten by TINAS with a more complete answer as usual. Wot he says. New wheel totally unnecessary
Posted : 12/10/2017 1:31 pm
Asked and answered, ta very much like.
