free hub locks unde...
[Closed] free hub locks under braking ?
Anyone else have their rear cassette lock under hard braking ?
Got a coaster brake type situation that only seems to happen under hard braking meaning the cranks wont rotate !Im assuming its the rear cassette locking anyway.
Its only a problem when one of the cranks is low and you try to rotate it to miss a rock or similar.
Ive just changed to a different wheel with a hope bulb but the same used to happen with my last wheel that had a shimano hub !!??
I get around it by releasing the rear brake to rotate the cranks but it can be a bugger when your just enjoying a good hoone !!
Is it just me ?
What dyou lot recon ?
Thanks
Posted : 02/07/2012 3:52 pm
Properly jammed or just a bit sticky? Stuck jockey wheel? If my jockey wheels need a clean/lube after a muddy ride the chain won't go backwards very easily.
I'd look there first and then consider overhauling the freehub if you still can't fix it.
Posted : 02/07/2012 3:55 pm
dont think so pixel it was fairly dry sunday and the jokeys are loose as a gordie lass after a few beers !!
The cranks lock up tight , no movement in either direction but free up as soon as braking force is reduced !?
Posted : 02/07/2012 4:01 pm
If you lock your back wheel then you can't pedal...
Posted : 02/07/2012 4:07 pm
Thats true enough njee but you should be able to rotate the cranks backwards as thats kinda what a free hub is all about surely !?
Posted : 02/07/2012 4:17 pm
Ah yes, missed the bit about not rotating either way.
Posted : 02/07/2012 4:18 pm
Besides Im not a skid happy youngster Ill have you know !! ๐Ÿ˜‰
Posted : 02/07/2012 4:21 pm
