Frame swap help, an...
[Closed] Frame swap help, and cable routing a patriot!
[#744429]
I have bought a Patriot frame from fleebay with the intention of doing regular frame swaps between that and the donor which is a P7 pro. I chose a Patriot with coil mainly for Alps use and because the mech and seat post will all fit. I have a headset on each frame, so really I thought swapping over would be simple. The only thing is to do it right I need to route the back break and gear cable. Is there a simple way to do this, or do I lash them to the swing arms or buy duplicates.
Posted : 29/07/2009 12:46 pm
guide the outer / hose through using a bit or wire e.g. a coat hanger
push the wire through
push the outer / hose on the end of the wire
pull it through
swear
repeat until done
Posted : 29/07/2009 12:58 pm
Lash it too the swing arm, or better still, buy a new rear break set up for the patriot and route it properly, and also buy a new gear out and route that properly
Posted : 29/07/2009 1:05 pm
I have hear of people routing brakes without need a bleed.... can this be done with avid juicy 5's.
Posted : 29/07/2009 1:33 pm
