Anybody found a solution?
Tried new pads, rotor and realignment.
My contact points find the vibrations really unnerving.
Potentially a leaky caliper contaminating pads?.
Rotor not centred on calliper?
Mine sounds same. No rub and brake looks ok when spin wheel standing next to bike. But under braking the rotor (200 so more flex?) moves and contacts calliper body I think. Horrendous brake chatter and vibration and squeal.
Not sure if I get you right, but I had terrible, howling resonance on my rear brake, on Ti HT if not pulling it down to the bars.
Ended up taping very tightly, with electric tape, about inch long M8 bolt into brake side seatstay. From the top of the stay.
Quiet and no resonance anymore. Friend of mine had the same on his FS bike. Same solution, same result.
Cheers!
I.
It is a Ti hardtail. Going to change all wheel bearings, freehub and install a spare XT rear brake complete unit with new pads and isopropyl alcohol the rotor. Will post up results. Taping on bolt will be last resort to alter resonant frequency.
Exactly that, pulling to bars brake works perfectly. Scrub speed and it sets off the vibrations.
My old Sanderson did this when I first got it - I sanded down the thick pain and really cleaned up all the mounts and surfaces to bare metal on metal basically, solving the issue.
I had a Life and a Breathe, both silent and ran with lovely feel. Due to Ti, no paint to rub off.
Have you tried wrapping old inner tubes around various tubes? Find the singing pipe and look for a more elegant solution.
Does it only do it at a certain speed? is it okay in the dry? It will be resonance if the frequency (rpm basically) is within 5%ish of the natural resonant frequency of the frame.
If it only does it et, or does it across the speed range, it's not resonance.
*et meant to be wet, too late to edit!
In my case it was just in certain speeds/conditions.
Added bolt fixed problem.
No other changes happened to that bike since, apart of new brake pads.
Cheers!
I.
You say you have realigned the caliper but can I ask how you realigned it?
If you just loosened the caliper off, pulled the brake lever then retightened the caliper then that could be the issue
If the pistons are not pushing out equally and squarely then this can cause the caliper to not be aligned properly when trying the above method and can cause uneven brake pad wear and give off resonance
Best bet is to remove the caliper, then remove the pads, pump out the pistons a bit, give them a good clean with isopropyl alcohol, then push them squarely back in the bores (using a blunt plastic tool like a tyre lever as not to damage the pistons)
Next refit the caliper (minus the pads) and centre it over the rotor by eye, tighten down making sure it doesn't move, then refit the pads and pull the brake, the pistons should move out squarely and the pads should then evenly touch the rotor and not rub or cause any resonance
Also worth checking your rotors are true and not contaminated
The only thing that cured this on my Trek was new rear brake under warranty. I have read people have glued some lead to the chain stay to alter its resonance; cant comment on that personally though. Could be the dreaded leaky calliper so start with that and dishwasher the rotors if you do to remove any deposits then replace the pads. I believe from experience that the fluid can seep into the pad and leach back out when heated so you can't clean the them properly.
I really appreciate the advice and time people have spent. I will follow that escrs.
