Frame mounted pump
[Closed] Frame mounted pump
[#10394446]
that I can strap to my gravel/cross/niche road/adventure bike all winter that I can expect to work when I finally remove it to pump up a tire and not spit water around and then disintegrate?
Please dont recommend anything Lezyne.
Posted : 17/12/2018 8:23 pm
I got this as I had to have an actual pump for a race
https://www.evanscycles.com/bontrager-air-rush-road-mini-pump-co2-inflator-00103188
Seems to work if you ever need to when the CO2 has been used (nice little backup to have really)
Posted : 17/12/2018 8:25 pm
 kilo
Specialised air tool road, not the mini pump version or if you're not shouldering the bike and it will fit a zefal box or the cheap Rev version
Posted : 17/12/2018 8:36 pm
Air tool road looks good. Spesh too so it will match my niche/road/adventure/gravel bike.
Posted : 17/12/2018 9:07 pm
Topeak Road Morph.
If you can get a wee bit of inner tube and slip it over the handle end, that'll also help keep the innards sealed. I've done this with the Mountain Morph on my fatbike too and that gets all sorts of abuse without affecting the functioning of the pump.
Posted : 17/12/2018 9:09 pm
Zefal HPX. Don't prat around, just buy it. Cheap, simple and works.
Posted : 17/12/2018 11:33 pm
