fox volume reducers...
[Closed] fox volume reducers / fox float r / mondraker dune.
Hi,
Riding a dune with fox float r shock. When sat at the right sag, 35%, it rides really well.
Except, it seems to use all the travel far too easily. Even an relatively sedate trails with only small jumps, drops and hits it pops the travel marking o-ring off the end of the shaft.
So, looking at these fox volume reducing spacers.
Anyone out there using them at all, not necessarily on a dune, and have any feed back?
Will they simply cause the spring rate to ramp as it works through the travel? Any ill effects?
Regards.
Posted : 18/04/2012 4:18 pm
Take a look at this: [url= http://forums.mtbr.com/turner/dw-5-spot-rp23-mod-503070.html ]DGC MOD[/url]
I plan to do it in next days on my Float R (spicy frame). Comes out much cheaper than volume spacers from Fox.
Posted : 18/04/2012 4:27 pm
Got the middle one in my RP23 on a Mojo and seems to be ticking the boxes. Running at lower pressure so small bump is better, doesn't appear to be blowing through mid-stroke and doesn't bottom out ๐Ÿ™‚
Posted : 18/04/2012 4:53 pm
That DGC MOD has made a great improvement to my Butcher and practically free to do
Posted : 18/04/2012 5:05 pm
