Fox Transfer + Shim...
[Closed] Fox Transfer + Shimano Lever = Pain in arse?
I'm running a new 2020 Fox Transfer post mated to a Shimano dropper lever. When I attached the cable and tensioned it, it worked fine. But now it refuses to release the saddle correctly, stopping about an inch short of the 'thunk!' point. I have reset the cable, pulling the cable very tight. Works fine on the work stand, doesn't work on the trail. Anyone got any ideas? Is the Shimano lever a poor match for the Fox post??? Thanks in advance.
Posted : 02/12/2019 1:31 pm
If working in the stand but not on the trail then maybe the cable is binding or getting caught somehow inside the frame when the suspension is compressed
Posted : 02/12/2019 1:57 pm
Hmmm, good one. I'll pull as much out of the frame as I can...
Posted : 02/12/2019 2:18 pm
I just ordered the xtr lever for 9120 brakes. 7mm cable pull apparently but I couldn't find any info on how much cable the transfer lever pulls.
Hopefully its compatible.
Posted : 02/12/2019 3:51 pm
