What's the difference in these shocks now then? Just renamed but basically the same damping etc? Can't really see much write up about them, but i always liked the rp23...
Isn't it now a lever for your terrain?
C -climb
T- trail
D - descent
Is your new one a ctd?
No more xv cans with ctd due to a change with the design of the eyelet area I understand. It means the volume spacers are used on the smaller cans. As above ctd shock has 3 compression tune settings.
[*][s]Mono - yep new one is ctd, was more wondering if they've changed the damper unit etc
I did wonder what happened to xv and the likes looks like they have mostly put everything all into this new design, must say in climb mode It's very solid almost like lockout, but not used it properly yet so was just hoping It's gonna perform just as well as the rp23
Which would be great if you can find somewhere that will sell you a spacer.
The Fox engineers have worked tirelessly over the last year to replace "1 2 3" with "C T D". Allegedly only the marketing dept has worked harder 😉
