My 2009 RP23 has a small issue with smoothness of travel. The first 5mm (only with air preload which I have at 180psi) of travel is a bit quick then bites and then is linear as you would expect. This has occured about a few weeks ago - when no air in teh chamber is soft and "linear" but I think the first bit of travel is availiable under pressure.
I'm going to to a sleeve service and see if that sorts it but anyone else have a problem - its not a high volume shock and this is only noticable when Pro-Pedal is off. There is no abnormal wear on the shock body and full travel and bottoming is not an issue.
Anyone had a similar issue ? Or is is overdue for a air sleeve service - TBH I havn't done it yet so I also have ordered a seal kit - kill 2 birds 😉
