Just done an air sleave service on my rear shock. pump it up, every thing fine. When i remove the shock pump all the air vents straight out the schraeder valve.
i've re-openned the canister to check for debris, but all fine. Re-inflated and lost the air again. Any ideas? new valve?if so where/
Could be a duff valve core.
IIRC it's a simple replacement with a standard schraeder valve inner.
if its a standard schraeder valve can i get that from Halfrauds + the tool to remove it?
Mojo also sell the whole valve assembly if needed- £15ish IIRC
i know i'm being thick but what does IIRC mean?
If I remember correctly. I sawed through mine.
Should just be the valve core.
It might just be loose. A valve core tool might be handy to just tighten it up.
If you have any tubes that use a schraeder valve then use one of those , been working fine in my Fox float AVA for the last 6 months.
do i need to buy a valve core remover or is there another way to remove it?
don't know any other way myself , sure someone will though.
You could always steal the lid off a bottle of slime in your local helfrauds. 😆 😳
Nokian tubes have a valve core remover in the cap.
all fixed ,
thanks guys
