FOX RP23 Bushings
[Closed] FOX RP23 Bushings
[#2536851]
does anyone know what size busing i need for a Fox rp23?
Thanks in advance
Posted : 06/03/2011 8:42 pm
12.7mm
Posted : 06/03/2011 8:51 pm
I got one of these for Fox DU removal and installation.
Works a treat.
http://cgi.ebay.co.uk/Fox-Shock-Bush-Removal-Tool-/110651538371?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item19c3587bc3
Posted : 06/03/2011 8:55 pm
im trying to find the correct ones but can't see them, also they mention a sleeve that needs putting in but when i removed the old bushings there didn't seem to be one?
Posted : 06/03/2011 9:00 pm
thanks for the reply but i don't need a removal tool.
Posted : 06/03/2011 9:01 pm
that sleeve you are talking about is probably the DU bushing?
Posted : 06/03/2011 9:02 pm
didn't see one when i removed the bushings
Posted : 06/03/2011 9:09 pm
is this what you removed?
Posted : 06/03/2011 9:13 pm
no that is still there, i took out the reducers i reckon
Posted : 06/03/2011 9:15 pm
That sleeve is the bushing. That is the bit that wears away, not the mounting kit (reducers). Well they do wear away but it's usually the DU that's worn.
Posted : 06/03/2011 9:17 pm
hmmmm doesn't look to bed but i do have some movement on the shock
Posted : 06/03/2011 9:21 pm
If the top hats just fell out easy the bush is likely to be worn
Posted : 06/03/2011 9:27 pm
cheers i'll order one and replace it just in case
Posted : 06/03/2011 9:29 pm
When you are looking for bushings and or a fitting tool for fox shocks, some people adveritse them as 1/2 inch, this is the same as 12.7mm as ltheisinger told you before. Makes sense when you think about it but it was confusing me earlier. 🙂 🙄
Posted : 06/03/2011 9:34 pm
lol cheers for the replys
Posted : 06/03/2011 10:56 pm
 LoCo
Hi as above 1/2" 12.7mm du bush I have them in at £1.50 each
Posted : 06/03/2011 11:16 pm
