Bottom Bracket Tool
[Closed] Bottom Bracket Tool
[#2536867]
Hi,
Can ayone tell me what type of bottom bracket tool will fit hope bottom brackets?
will my sram BB tool fit.
Also, is there any other way of tightening the BB without the expensive tool without damaging the BB?
Help would be appreciated.
Al
Posted : 06/03/2011 8:42 pm
Park BB9T, BB19T or similar, pretty sure it's the same fitting for Sram GXP if that's what you've got.
Posted : 06/03/2011 10:08 pm
I've used the same tool on both Hope and SRAM/Truvativ BBs.
I wouldn't attempt it without the proper tool. It's only a thin bit of aluminium. Stillsons or mole grips would almost certainly crush it out of shape.
Posted : 06/03/2011 10:21 pm
Your SRAM BB tool will work fine, you can get external BB tools for £8 given the price of Hope BB that's cheap. I'd not risk using anything but a proper tool or you can up breaking your BB cup.
Posted : 07/03/2011 10:03 am
Thanks guys,
but will the sram BB tool directly fit the hope one?
Really appreciate your help.
Thanks again,
Al
Posted : 07/03/2011 9:00 pm
Truvativ, Shimano, Race Face, Hope, Superstar, etc. external bearings all use the same interface (and thus the same tool).
Posted : 07/03/2011 9:14 pm
Not all SRAM/Truvativ cranks are external though so no guarantee that the SRAM tool mentioned is compatible with Hope unless it's a SRAM tool for an external BB.
If you find you need a new one, the Superstar one is spot on btw.
Posted : 07/03/2011 9:17 pm
appreciated,
thanks
Posted : 08/03/2011 10:27 pm
