Fox RP23 boost valv...
[Closed] Fox RP23 boost valve pro pedal doesn't do anything can anyone help ?
Hi thanks for reading this I've just bought a Chumba vf2 and it came with a Fox RP23 boost valve rear shock but when the pro pedal doesn't do anything even on the 3 setting I'm bouncing round like I'm on acid !! Anyone have the same problem if so how do I fix it maybe service ?? Cheers ,Mark
Posted : 30/11/2016 6:23 pm
It's borked. Needs a full stripdown and service. £100 ish from TF tuned.
I've found that my recently built up (5 months after purchasing) eBay frame has the same problem.. 🙁
Sad that some sellers aren't able to reveal crucial bits of information like this.. Hey-de-ho..
Posted : 30/11/2016 6:30 pm
Shit and blast !! Thanks pal looks like the kids aren't getting as much as they thought this year
Posted : 30/11/2016 6:46 pm
Might not be broken. I had the same thing on a commencal. Sent it off to tf tuned to get pushed and they adjusted the feel at each setting.
Posted : 30/11/2016 7:48 pm
How much did that cost ?
Posted : 30/11/2016 7:55 pm
Its not broken, it just needs a service / nitrogen charge.
Posted : 30/11/2016 8:03 pm
Thanks Devash I'm liking that answer most
Posted : 30/11/2016 8:13 pm
It seems a common problem. TF sorted mine.
Posted : 30/11/2016 8:15 pm
Looks like TF then thanks everyone
Posted : 30/11/2016 8:18 pm
When you say it's causing you to bounce around, could it not just be you need to increase the rebound damping to stop the shock springing back too quickly ? (turn the red dial clockwise to increase damping).
I can't say I've ever noticed that my pro-pedal does anything, and that's since new. I've never bothered getting it checked as my Maestro linkages do a good job at reducing 'pedal bob' but I've always suspected it's been broken since new. However, the rebound damping has always been OK. As someone mentioned above, I think the pro-pedal relies on the nitrogen charge.
Another reason a poorly tuned RP23 can be too bouncy is when you're having to put a lot of air pressure in to prevent the shock bottoming out. This was happening on mine, so I fitted Fox air volume reducers, and they did make a difference.
Posted : 30/11/2016 10:24 pm
I've played around with the rebound and it's hardly made a difference my Heckler and Jamis Dakar are both fox rp23 and they are set up bang on I'm just gonna bite the bullet and get it serviced
Posted : 30/11/2016 10:35 pm
