Fox RP23 air pressu...
[Closed] Fox RP23 air pressure guide for alpine 160?
My frame is second hand, so no manual. I'm struggling to find a guide for shock pressure, can anyone help please?
Posted : 26/08/2011 10:06 am
Forget any guides (some are just completely wrong), you need to do it to match your weight, this is easily done by trail and error:
Decide how much sag you want to run (20-30% normally), pump it up to match your weight in lbs = psi as an initial starting point. Check the sag measurements by seeing where the o-ring is pushed down to (with you on it full kitted up [ei: inc rucksack]), then adjust (add or remove) air pressure to get the sag you want.
EDIT: With an RP23 make sure your not in "pro-pedal" mode when you do this.
Posted : 26/08/2011 10:17 am
Like what you did there ๐Ÿ™‚
Posted : 26/08/2011 10:20 am
 LoCo
Have a look at the setup guide ๐Ÿ˜€
http://locotuning.co.uk/tech-info.html
Posted : 26/08/2011 10:22 am
opps ๐Ÿ˜ณ yeah sometimes my mad typing skillz amaze me too*, obviously did it on porpose....
* the edit button has helped me quite a lot of late...
Thanks guys.
Posted : 26/08/2011 10:24 am
Try running it a bit more saggy say 35%.
I did and loved it. The air shock ramps up alot so still no harsh bottom out. relaxes the front end too.
Posted : 27/08/2011 5:47 pm
