Fox RP2 Pro-pedal l...
[Closed] Fox RP2 Pro-pedal lever moves rebound dial
[#1413260]
I keep ending up with no rebound on my shock - this appears to be because changing from pro-pedal to no pro-pedal (or vice-versa) is moving the rebound dial. Anyone else get this and is there anything I can do to fix it or is it a 'feature' of the shock? Thanks.
Posted : 15/03/2010 1:18 pm
Yes,I get it too sometimes. I've just been giving it a little bit more of a clean and a drop of lube, that reduces the problem but doesn't eliminate it.
Posted : 15/03/2010 1:20 pm
 LoCo
Take the propedal lever off using the very small allen grub screw in the lever (NOT ON THE BODY OF THE SHOCK)(sorry but have seen a number of shocks with 'customer modified' rebound dials with no oil in 😕 ))
Clean all dirt from underneath and on top of rebound dial then Pop a little light grease on and refit.
Check propedal lever is properly seated and done up tight. 😉
Posted : 15/03/2010 1:45 pm
Strikes through previous typing - LoCo is correct
Posted : 15/03/2010 1:49 pm
Thanks for the replies. I'll head out to the garage later for a careful fettle!
Posted : 15/03/2010 1:53 pm
