Is there another name for this fork as I cannot find it in their website product range?
It is this one; Fox 34 Rhythm, 150mm Travel, FIT4 Damper, Boost 15x110, Tapered
I think it's OEM only isn't it? Might limit the amount of literature for it.
What is OEM lol?
No wonder you can't find owt!! You have heard of google right?? 😉
https://en.wikipedia.org/wiki/Original_equipment_manufacturer
Lol so its not fox at all then? just want to know how to service it when the time comes.
Correct, it's not fox. All OEM equipment is made by ACME manufacturing inc.
Didn't think the rhythm fork had the fit4 damper just the basic version , I think it's the performance version and above that has fit4.
Lol
Its very confusing, so this ACME company makes them?
Only when they're not making anvils.
or safes
I was getting worried because the stuff the Coyote used never really worked.
Back on a serious note this is how they are specced on the bike I'm getting; Fox 34 Rhythm, 150mm Travel, FIT4 Damper, Boost 15x110, Tapered.
Just wanted to be able to find a service guide for them, for the future.
I'm billing you for my keyboard.
OP: I'm sure it's the GRIP damper, not the FIT4.
As far as I'm aware it's basically an entry level Fox 34.
Chassis is the same/ver similar, air spring the same/very similar, different damper, so unless you're doing a damper service I'd be using service procedures for a 'normal' 34.
Ok thanks, so the float version then?
It's essentially a normal 34 with a grip damper (open bath) follow service intervals for a float 34
Thanks for the replys, and lols
