Fox rear shock seal...
[Closed] Fox rear shock seal kit query?
[#2140937]
Hi I've just recieved a set of fox rear shock seals from Mojo and have noticed prior to opening that two of the four white washers are split and do not make a complete ring.
Is this how they should be or have I got a dud? I did try phoning Mojo however they are shut over the weekend.
Cheers 🙂
Posted : 30/10/2010 1:35 pm
Yes, they should be split
Posted : 30/10/2010 1:44 pm
That's how they are don't panic.
They go on the shock body so they need to have a split otherwise you couldnt fit them!
I suggest you visit the Fox website as they have a step by step guide on how to replace the bushings and seals on float rear shocks.
Posted : 30/10/2010 2:04 pm
Phew, I did wonder when I got the packet. Once I finished doing my fork I'll get on with the shock.
Cheers guys 🙂
Posted : 30/10/2010 2:09 pm
Check this out..
Posted : 30/10/2010 5:12 pm
