Fox Oil Change Ques...
[Closed] Fox Oil Change Question
[#3038405]
Changed the suspension oil on my F29 RLCs last night
Is there an easier way of getting the oil in the damper side? - the damper rod doesn't come up far enough to allow the oil to be easily squirted it and it must have taken a good 5 mins to get the full 30cc in
Is there any reason why I can't install the damper rod, flip the forks over and fill the stanchions from the bottom before putting the lowers back on?
Posted : 11/08/2011 10:08 am
 LoCo
lowers on, damper top cap done up loosely, fill spring side, from bottom, do both lower nuts up, turn fork back over, undo damper top cap and fill. 😀
Posted : 11/08/2011 10:10 am
i use a really big syringe 60ml (fleabay pennies) makes life a lot easier and less messy.
Posted : 11/08/2011 10:16 am
I used a syringe, the gap at the side of the damper is only around 2mm and it doesn't work it's way through very quickly
Posted : 11/08/2011 10:20 am
 LoCo
Compress/ extend the forks as necessary, let the air out or hold valve open when moving forks and then release to hold in place, make them do the work 😉
Posted : 11/08/2011 11:43 am
OK cheers, I'll try that next time
Posted : 11/08/2011 4:15 pm
