I am going to service my Flox float fox. i tought i had everything i needed until i check the oil volumes list.
fox float fluid - check
fox 10wt green - check
fox 10wt red - what???
are the 10wt oil not the same or am i missing something?
i already had the other oil from doing the seal service , do i need the 10wt red?
link to oil volumes if that helps.
http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm
my fork are the fox float 32 rl , number 37 in the list.
plus mojo don't list a red 10wt oil 😕
the green stuff is all you need
the red is for the damper internals I think
The red oil is used for the FIT damper, goes in the bladder. I think your brave if you are going to take the FIT damper apart! Otherwise if your just removing to clean the insides of the lowers and stancions you are OK as you normally use 10ml in the left leg and 30ml in the right leg(damper side) as lubrication.
ruscle,
i was going to remove the air spring and clean and re-fit. i was going to leave the dampener alone. Not that brave>
I emailed Mojo with this exact query - got the answer that the green 10wt was fine for both uses. (obviously still need the float fluid though)
