Fox Fork Issue
[Closed] Fox Fork Issue
I have just tried to do a fluid change on my Fox Talas. I am trying to tighten the nut on the damper side - the one where the rebound knob is located. The issue is the thread is also turning. The whole inner mechanism is rotating. Is this game over and a job for the professionals? If not what can I do?
Posted : 06/06/2015 4:49 pm
Just thought I'd share what I did to resolve this in case anyone in a similar predicament is searching for an answer at some point. I was able to wind out the rebound adjuster and then carefully hold it using a pair of pliers while using an open end spanner to very very gently tighten the nut up.
Seemed fine on Sundays ride and there was no leaking fluid.
Posted : 08/06/2015 2:43 pm
have employed cubist's method before, just don't grab it so tight that you crush threads and it'll be grand (good pliers help)
Posted : 08/06/2015 3:38 pm
you can try compressing the fork with a luggage strap or your foot on the brace too.
Posted : 08/06/2015 3:41 pm
Tried compressing them but it wasn't enough for my 2012 Talas 32s. It must have taken 2 hours of huffing, puffing and swearing before I managed to find something that worked. It just feels so wrong holding on to such a fragile part like that ( phnarr phnarr etc...)
Posted : 08/06/2015 6:33 pm
The air side of my RL s Do that if I let the pressure out before loosening (but not removing) the lower nut. Maybe doing the compression thing on that side would do the same?
Posted : 08/06/2015 8:16 pm
