I’m in the process of buy a lightly used Float X Evol for my Transition Scout, which the seller tells me was bought after market.
Couple of questions, having been bought after market and not part of a full build/frame, I assume the shock shouldn’t have any tune (unless the seller has had this done).
And are Float X’s a good shock that’ll work well with the horst link suspension. It’s going to replace a Monarch RT3 witch I believe an M/M tune (and currently has a broken lockout).
I love my Float X - it was also bought after-market but I was asked for a frame / rider weight so I guess they come with some tailoring.
scout has an LL tune
Well seller says nothing was set up for him when he bought it from his LBS, so that's that answered (hopefully).
Poah, I 'think' the older frames, mines a 2016, where MM. There's every chance I'm wrong though!
shock will say LL or MM on it
I'll check when I get home but hopefully should make to much difference if it's an un-molested shock?
