Fox Float RP23 Help...
[Closed] Fox Float RP23 Help req please !!
[#3384837]
Hi !! I've just put some air into my RP23 shock and when removing the pump from the shock by unscrewing the valve all the air escapes from the shock. I've put air into it in the past and never had this problem. Has anybody any ideas what might be making all the air escape please ? Many thanks !!
Posted : 23/11/2011 10:26 pm
Valves probably defunked hence air escaping try loco or TF for a new valve stem perhaps
Posted : 23/11/2011 10:27 pm
all the air? a leaky valve stem. Replace from a schraeder tube using needle nosed pliers
Posted : 23/11/2011 10:28 pm
if its not just air escaping from the pump and you are atually losing the air from shock, try a new valve core. You can just remove one from a shraeder tube.
Or maybe yours had just come loose and needs nipped up.
Posted : 23/11/2011 10:29 pm
Many many thanks everyone for the help !! I've got a valve stem remover so I'll give that a go removing the one from the shock and replace it with one from an inner tube. The air is definately coming from the shock and not the pump.
Posted : 23/11/2011 10:33 pm
Just replaced the valve and hey presto no air escaping. I really can't thanks you all enough for the help in getting this sorted out for me. Really do appreciate it !!
Posted : 23/11/2011 10:44 pm
