I believe that the travel on Fox 150 FIT can be reduced to 140mm by use of a small spacer; easy to do or LBS job? Happy with basic oil changes etc but not much more ๐
thanks for replies and any key workshop links
It's really easy to do as long as you have the tools you need and some Fox Float fluid. Overall it takes about 10 minutes. Here's the link to the user manual that describes it.
[url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/011/index.html ]Fox Tech Centre[/url]
EDIT Just realised that I've only done it on a Fox 36 Float, not a Fox 32 FLoat and the tech centre doesn't seem to have instructions for reducing travel on the 32. I am assuming it's the same as for the 36, but I would call Mojo and ask to be on the safe side. Sorry to confuse.
