Fox float oil repla...
[Closed] Fox float oil replacement - stupid question
Ok , so my stanchion-worn 2010 fox 32 fork has been in the shed with lowers off for ages and I want to rebuild for a hack bike. Problem is , the steerer has been hanging down and the oil has dripped out from the internals I have lubed up seals and replaced the lowers and now am unsure where to put in the 10wt oil - the Fox service website says I need 160ml in damper side ( right leg ? ) and 30ml in spring side oil bath ( left leg?) . Does this get syringed in before tightening on the lowers or do I need to remove top cap from right leg and syinge the 160ml oil in there ?
Posted : 08/12/2012 6:14 pm
 LoCo
160 into top of damper leg if you have the appropriate tools as it's easier, and 30 in the lower leg of the air spring side.
Posted : 08/12/2012 6:16 pm
You have to remove the top cap and put it in there, I funnelled it into the bottom of the leg before putting the bolts in and tightening the legs up, when I turned the bike over and pushed down the seals blew out and the oil followed.
Posted : 08/12/2012 6:18 pm
Thanks guys. Appreciate the info.
Posted : 08/12/2012 9:01 pm
