I have the above fork - do they have oil in the lowers a la rock shox or not?
If so - how much of what in each leg?
On the fox site it says:
FOX 10 wt. Damper 160.0
FOX 7 wt. Spring-side Oil Bath 30.0
FOX Float Fluid Air Chamber 5.0
I assume that the 160ml of 10wt is in the actual rebound/compression side (top of fork)
The 30ml of 7wt in the spring side oil bath - is that the lower? What about the other side?
I know the float fluid goes in teh air chanmber like in the air sleeve of the Rear shox.
Surely they don't run the lowers dry??
anyone????
wooooo, chill!
160 in the RH, splashes around and acts as lowers lubes too (in a non FIT fork anyhow)
20ml in LH lowers
float fluid in the air chamber
HTH
cheers si 🙂 sure? 😉
