Fox dpx2 high press...
[Closed] Fox dpx2 high pressure to achieve 30% sag
Hello. Quick question. First experience with this shock on my new bike, hb130. I'm finding I need 270psi to achieve 30% sag (15mm between wiper seal and o ring) with weight of 13 stone. I've equalised the Chambers every 50psi when filling up. Is this normal, somthint I've done wrong? Faulty shock?
Thanks
Posted : 21/11/2021 10:53 am
I could be wrong but I think you still have another 100 or psi before it maxes out so it could be right.
Posted : 21/11/2021 12:22 pm
The DPX2 can take 350psi, same as the X2 i believe, they are high pressure shocks, and i wish Fox had actually designed a shock pump to work with them better than the normal ones on the market, as it's a pain having to pump them up to those pressures!
Posted : 21/11/2021 12:48 pm
Yes, totally normal. I was surprised when I first set mine up. I need 235psi on a 130mm travel bike, 55mm shock stroke, 80kg. On an equivalent rockshox I need about 175psi.
Posted : 21/11/2021 12:55 pm
Yes my hefty bulk requires 280 in mine and its fine
Posted : 21/11/2021 1:05 pm
