[url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390131784511&ssPageName=STRK:MEWAX:IT ]Ebay[/url]
Right ones for Float forks?
yep black ones for 32mm fork, silver one pictured is for talas forks on the talas side. Have you called mojo? might be cheaper. 01633 615815
I know you get them with the wiper seal kit, nad they're supposed to be replaced every time you undo the lower mounting bolts, but tbh i've always re-used them in between seal changes, what harm could it do??
£7,99 on mojo for 8 crush washers . they dont sell them seperately . i didnt replace mine when i done seal service maybe next time
I reused mine, but it was distorted and leaks a little bit. Yep, didn't want to have to buy a £7.99 (+p&p) lot from Mojo.
i reuse two or three times - just file out the threads that are squashed into the inner surface and slide back onto the threaded rod. Works a treat. Do it too many times though and you'll thin the washer too much!
I was ordering some other stuff from mojo so got a packet for 32mm forks. Only need a few myself, can send anyone a pair at cost if interested. Email in profile.
