fox 36 on a stiffe...
[Closed] fox 36 on a stiffee
 rb
[#1810811]
do anyone know if you can run fox 36 forks on a cove stiffee or would i be better sticking with 32s and is there much diffrence between Q/R and bolt thru
Posted : 18/07/2010 5:25 pm
Tried it, 160mm is too much.
Old cove site said you can run 7 inch dual crowns on them. The geometry would be pretty odd.
You can get 32s with a 15mm through axle.
Mine felt best with 120mm maxle rebas.
Posted : 18/07/2010 5:32 pm
its a FR frame, the Cove* site pictures a 2010 one with Lyrics on it, so yea it'll thank you for a set of 36's - go TALAS if your unsure
*150 Max Ride Height of 520mm.
Posted : 18/07/2010 6:22 pm
I run a set of 150mm 36 Talas R's on my Stiffee. It feels great. To make it more niche it's also single speed.
Posted : 18/07/2010 7:04 pm
 rb
thanks for the advice it runnig pikes at the mo but there worn out so looking at new forks, thinking about going single speed for the winter
Posted : 18/07/2010 7:14 pm
 scud
RB - I don't suppose you want to swap your Pikes for a set of Fox 36 2007 Talas 110-150mm adjustment?
If so email is in profile.
Posted : 18/07/2010 7:40 pm
