Hi all,
Just gave my 2022 forks a lower leg service. As I was sliding them back through the headtube I noticed a spring washer on the floor that could only have come from when I disassembled them. I think it's from the rebound dials but not 100% sure. Can't find anything about it in the service manuals/fox website.
The mystery washer:
[url= https://i.postimg.cc/X7b9cF3v/IMG-20230428-084557373.jp g" target="_blank">https://i.postimg.cc/X7b9cF3v/IMG-20230428-084557373.jp g"/> [/img][/url]
Anyone know for sure where it's from? Grip2 damper if that helps.
Cheers.
Sits under the red rebound adjuster, between the high and low speed.
Cheers!
Really don't want to have bits left over when putting forks back together...
Step 45
Install the larger High-Speed Rebound (HSR) knob with its thinner rim facing toward the bottom nut. Coat the wave spring with a thin film of Slick Honey then install the smaller Low-Speed Rebound (LSR) knob with the wave spring between the two knobs. Put slight pressure on the LSR knob so that there is a bit of preload on the wave spring. Align the set screw with the flat on the LSR needle then tighten clockwise to 8 in-lb (0.9 Nm) torque with a 2mm hex wrench. Test that both knobs turn freely without binding.
