Fox 36 Grip 2 - kno...
Fox 36 Grip 2 - knocking noise on compression+Rebound
[#12719663]
As above;
Serviced lowers but accidentally stroked the damper rod which released more oil from the damper, filled legs with correct amount of the recommended oil, now have a knocking noise/clunk on compression and a knock on rebound. Ridden for 3 hours since service and has not cleared.
Air in system should self bleed? Is the recommended refill amount just to replace the naturally drained oil, so maybe I need to add more to compensate for the purged oil?
Thanks
Posted : 10/02/2023 7:04 pm
 Jamz
When you say that there was oil coming from the damper where do you mean exactly?
A lowers service doesn't require removal of the damper?
Posted : 11/02/2023 11:56 am
You've purged oil from the damper and not replaced it. Thats why.
Oil in the leg is intended for a different purpose, although, the 36 design anticipates the damper ingesting some of the semi-bath - it's why its the same in the leg as the damper.
I'd not rely on that to top it up though, although I suppose it will over time, at cost of less fluid in the semi-bath.
Posted : 11/02/2023 1:13 pm
How do you replace it, I thought it was self bleeding and would take oil from the bath.Any help with how to refill it would be great if that's not the case.
Ta
Posted : 11/02/2023 3:09 pm
Its auto bleeding, not auto filling.
You take the top of the cartridge and tip it in.
Posted : 11/02/2023 4:43 pm
