Fox 36 180mm TALAS ...
[Closed] Fox 36 180mm TALAS R
[#2782727]
Does anyone know whether changing the travel on a Fox 36 180mm TALAS R reduce the axle to crown height?
Or does the height remain the same regardless of travel setting?
I'm guessing the fact I can't find an answer on the Fox website means it's the latter...
Posted : 23/05/2011 9:40 pm
 igm
Check out the guide on how to fit spacers - assuming it's the same as the 32mm forks. I think it effectively causes the fork to hit the top out sooner which would reduce the A2C height.
Posted : 23/05/2011 9:51 pm
 flow
Reduces the height however much you reduce the travel
Posted : 23/05/2011 10:03 pm
It's the change-travel-on-the-fly-with-a-lever version. I want 140mm short forks on the way up but slack-as-you-like 180mm monsters on the way down!
Might be looking for something that doesn't exist.
Posted : 23/05/2011 10:05 pm
flow - defo?
Posted : 23/05/2011 10:06 pm
 flow
Yes 100%, couldn't be more sure in fact.
Posted : 23/05/2011 10:08 pm
 igm
Apologies - wrong end of stick. I was thinking you wanted to reduce the 180 down to 170 or 160 (and yes I can think of a reason why I'd want to do that)
Posted : 23/05/2011 10:12 pm
 flow
Even if you did do that it would do the same thing ayyyyyy
Posted : 23/05/2011 10:18 pm
Wicked - ta v much! Think I'm sold. Now to sell the first born...
Posted : 23/05/2011 10:45 pm
 flow
Posted : 23/05/2011 10:50 pm
