fox 34 Volume space...
[Closed] fox 34 Volume spacers - Giant Anthem 2017 ?
I have an Anthem 1, fork being :
Fox 34 Float Performance Elite, 120mm Travel, FIT Damper, 15x100 KaBolt, Tapered
and I weigh 13 stone in riding kit.ย  Wondering what the standard as supplied spacer set up is likely to be, and whether I should get a spacer removed ?ย  I have the fork at 85PSI and sag is perfect - I rarely get full 120mm out of it, though often most of it.ย  Not sure if I am in about the right place or whether removing one would cause me to bottom it out a bit ?
thoughts ?
Posted : 26/02/2018 1:12 pm
fork is due a service soon so will ask then at LBS methinks
Posted : 26/02/2018 2:33 pm
