fox 34 axle...what&...
[Closed] fox 34 axle...what's this??
my friend bought himself a Mondraker Dune XR. it came kitted with some Fox 34 CTD's.
but we're both a bit baffled by these numbers on the fork axle...
does anyone know what they mean?
Posted : 16/06/2015 2:38 pm
Tension adjustment
[url= http://www.ridefox.com/fox_tech_center/owners_manuals/010/eng/Content/Forks/32MM/InstructionsQR32mm.html ]Here[/url]
Posted : 16/06/2015 2:40 pm
Isn't that the gnar dial ๐Ÿ˜†
Posted : 16/06/2015 2:41 pm
It's just so you can rotate the QR lever to your preferred angle. No idea why it has numbers.
Posted : 16/06/2015 2:42 pm
That as well whack it up to Enduro level ๐Ÿ˜€
Can't believe you're still only on 2, no ones on 2 anymore. Like Jeeeeezzzzzeeeee.
Posted : 16/06/2015 2:46 pm
thats what i was hoping you'd say
give the guy a chance...he's only had it a few days!! if it was mine i'd crank it up to full!! ๐Ÿ˜€
Posted : 16/06/2015 3:17 pm
not quite Shredder, its purely for setting the position of the closed QR lever when at the correct tension.
Posted : 16/06/2015 3:19 pm
Technically its an axle nut, but I think tension adjuster works well too ๐Ÿ˜‰
Posted : 16/06/2015 3:59 pm
If only someone had bothered to say that already ๐Ÿ˜•
Posted : 16/06/2015 4:07 pm
