Evening all
I know the Trickstuff Excentriker is available via SJS cycles. Is the Forward Components version readily available? Not having much luck via 'tinternet'
Is it a bsa bb on your S works?
Hi bud. The s-works has a bb30 shell, but it has a adapter kit so I'm running a standard threaded cups.
I've got one lying around which worked fine for the time that I was using it but now that I've got two SS specific frames I don't need it, although I've been hanging onto it "just in case"....
One of the top hat plastic bushing has separated into two pieces but it still works fine. If you're interested in it give me a shout - I bought it direct from Trickstuff BTW.
As far as I know the Forward Components one is no longer made.
Rorschach, apologies for daft question, with that adapter, do I still use the standard threaded cups and crank?
Nah. It replaces the BSA adaptor and bb cups.
(you can replace bearings when they wear out). Your existing cranks just slide straight in (might need a half link as it doesn't have massive throw ). The only issue is that it's £150 :0(
£150! Ouch.....
Actually £130....marginally less ouchy(ish)
