Fort William / Lagg...
[Closed] Fort William / Laggan conditions
[#1074771]
Thinking of riding one of the above xc trails this weekend. Any thoughts on conditons after the recent deluge?
Posted : 25/11/2009 9:44 pm
i think fort bill is closed for the winter. laggan drains pretty well but it will have taken a battering with all this rain. good luck.
Posted : 25/11/2009 10:02 pm
it's only the DH trails that shut for winter. was out in the central highlands yesterday - hills are very wet, but i've seen worse. trail centres will be fine (unless the wind has brought some trees down).
Posted : 25/11/2009 10:10 pm
I did one of the Witches Trails XC routes last winter when there was snow all over the shop.
Posted : 25/11/2009 10:23 pm
Deluge is normal for FW.
Posted : 25/11/2009 10:25 pm
Was probably going to do the witches if I go to Fort William unless it's too churned up. Can easily come home via Laggan otherwise since I reckon that might drain better. I knew the DH stuff would be shut. Reckon I'll try the new XC next year when the lift opens again.
Posted : 25/11/2009 11:03 pm
Have you done the Witches Trails before? Not all that imo - some good bits but some dull ones too and lots of fire road.
Posted : 25/11/2009 11:05 pm
Not ridden either grumm. Better to go to Laggan? Was veering towards Fort William as I'm coming back from Skye, and I'm up that way less often, whereas Laggan is a bit closer.
Posted : 25/11/2009 11:21 pm
Laggan has some diversions on for forest work.
Posted : 25/11/2009 11:29 pm
The Laggan diversion is non issue and only effects the initial climb from the carpark to the bottom of the upper red/black . . . and the diversion is more interesting . . . diversion also not in place at the weekends per the signage . . . I was there Monday afternoon and it was very wet, the lower red was like biking down a river . . . I expect it'll be more of the same or wetter if the weather today was anything to go by . . . still . . . no big issue . . .
Fd
Posted : 25/11/2009 11:39 pm
 Kit
Laggan almost exactly a year ago... bit different weather then!
http://www.flickr.com/photos/gingerfox/sets/72157610474210119/
Posted : 25/11/2009 11:51 pm
Nice, snow on the peaks on Monday, temp is dropping so the snowline will be coming down the hills shortly 😉
Fd
Posted : 25/11/2009 11:59 pm
Speaking to someone today who had driven down from Inverness this AM and there was snow at Drumochter . . . certainly turned a lot colder today . . .
Posted : 26/11/2009 6:52 pm
Like Grumm said, the Witches Trails aren't all that. The good bits are very good I think but there's soooo much fire road. Even fire road descending, which is a bookable offence. And the signposting is absolutely awful.
Still, there's bits on the descents that I'm really burning to ride again, they have a brilliant, carved out of the woods feeling which is pretty different to most trail centres. It's not massively difficult for most of it but it doesn't feel like it's coddling you as reds can. And I think you might be able to cut out most of the tedium if you loop just the western end, cut up from Witch's Brew or Nessie to Great Glen Helter Skelter without going back to the main car park (if I was going to try this I'd start from the North Face car park)
Personally I'd save it til the lifts are open- you can build a nice day doing the nevis red then once the bikes get kicked off, chain up bits of 10 under the ben and the witch's.
Posted : 26/11/2009 9:20 pm
 Smee
Fort Bill is excellent if you take a look around and go off piste a little.
Posted : 26/11/2009 9:24 pm
Thanks for the comments. I agree that fort bill next year when the downhill xc red is open would make a good day. Snow at Drumtocher? There is always snow at drumochter from November til May!
Posted : 26/11/2009 9:39 pm
Goan, I was wondering that, there's a million little trailheads and tempting diversions isn't there...
Posted : 26/11/2009 10:02 pm
 Smee
Yip. Lots of them. All good too. You could spends days in there and not ride the same bit twice.
Posted : 26/11/2009 11:57 pm
Course, the midges will leave nothing but a bleached skeleton :mrgreen:
Posted : 27/11/2009 12:41 am
Thanks for the comments. Rode the lower red today. Not been out for a couple of months, so didn't fancy the black, but the lower red was a good taster. Reckon I'll need to zip up the A9 again soon. Not as much snow as the above shot, but a few flakes in the air!
Posted : 29/11/2009 8:05 pm
Rode Laggan yesterday, black/red x 2 , then the red to the bottom. A bit damp but no issues on trail. Boardwalk was a bit slidy.
Posted : 29/11/2009 8:15 pm
