Formula RXC-142A re...
[Closed] Formula RXC-142A rear hub bearing replacement
Has anyone replaced the bearings on one of these? I have had a look on the net for a manual but have drawn a blank so far. Is my googling weak?
Posted : 05/03/2021 11:00 am
Quick Google suggests non drive is a 6902 and driveside inside freehub is a 15267 if that's any help
An exploded view of the hub is in this link
https://bicycles.stackexchange.com/questions/58578/remove-bearing-cartridge-on-a-formula-rx-142-hub
Posted : 05/03/2021 11:36 am
Ah yes, I found that diagram but mine is a centre-lock and only has a flat sided nut on the drive side. It has what looks like a pull off cap on the non-drive side but it won't pull off. I thought perhaps the axle was hexagonal inside to take a large allen key, but it is round.
EDIT - needed a damn good pull but the non-drive side popped off in the end.
Posted : 05/03/2021 12:08 pm
Does that expose the bearing?
Posted : 05/03/2021 2:23 pm
Yep, should be pretty straight forward now. Not only was my googling weak, but so was my tugging technique.
Posted : 05/03/2021 3:59 pm
Haha. Well as long as you're happy😁
Posted : 05/03/2021 5:13 pm
