Formula Oro bleed s...
[Closed] Formula Oro bleed screw fitting?
 TimS
[#1918878]
Hello,
I need to bleed my Formula Oros, and I'm feeling a bit tight to spring for the official bleed kit -- £20 for a couple of syringes and a pair of screw fittings seems like theft. Does anyone know what the screw thread on the bleed screws is -- I'll source some fittings from our local hydraulic supply place.
Posted : 21/08/2010 10:58 pm
It's the same size as for the Avid bleed kit, if the info is easier to find for that.
Posted : 21/08/2010 11:10 pm
Aquarium pipe joins cut with a correct sized M bolt have been known to work. Plastic is so soft it cuts easily and they are cheaper than chips. Use the line too. However I use an Avid Kit, like the previous chap.
Posted : 21/08/2010 11:14 pm
