fork-oil substitute...
[Closed] fork-oil substitute....will i die?
[#6062407]
Having no fork-oil yesterday and wanting to service my X-Fusion Hi-lo dropper Ive used Slick 50 power-steering fluid which is essentially ATF oil. Viscosity seems pretty much the same.
Havent tested yet as i need to locate my shock pump.
Will i die?
Posted : 24/03/2014 10:42 pm
My bet is you will live for another 43 years. No idea about your oil tho, sorry..
Posted : 24/03/2014 11:35 pm
DO NOT DO THAT! GET IT OUT OF YOUR POST ASAP! Power steering fluid is highly combustible under compression, which could result in the post exploding and you with a saddle lodged somewhere in your intestines.
Maybe.
Well, probably not.
Honestly, I've no idea, but this is STW so knowledge is not really a pre-requisite of a response.
Tbh, it'll probably be reet. Might damage some rubber seals, maybe? But you'll probably not die.
Posted : 25/03/2014 12:22 am
i have a deore brake which has worked perfectly on 3in1 oil for years.
i have used ep80 gear oil to fill my ancient rock shox toras, they work, about as well as they did when new. {ie: not very well}
Posted : 25/03/2014 12:43 am
****inhell pinetree...had me worried for a minute.. 😀
Posted : 25/03/2014 1:03 am
martymac - Member
Really? This is interesting.
Posted : 25/03/2014 8:02 am
Martymac is good at fixing stuff. He always uses the right tool for the job.
Posted : 25/03/2014 8:42 am
I used engine oil for old camper vans in a set of Rockshox Dukes and had no problems
Posted : 25/03/2014 8:48 am
