Fork oil....
[Closed] Fork oil....
[#478777]
Hi all,
I have a Pace RC40XCFR fork,2005 model,& on the servicing instructions it says to use 10wt oil.Problem is,i've run out of the stuff!I do,however,have plenty of 7wt oil.So,could I use this instead,will it be detrimental,or improve the performance of the fork?
How do the oil weights work,is 10wt thicker than 7wt,or vice versa?
Gaz
Posted : 17/04/2009 12:45 am
10wt is thicker than 7wt and so will give more damping, you could use the 7wt and correct for the difference with changing the air gap but personally i would run down to halfords and pick up a bottle for a fiver...
Posted : 17/04/2009 2:24 am
depends what brand of 7wt you have and what brand of 10wt the manual calls for. Not all 10wt oils are equal. There's a table produced by a chap on a site called PVD designs or something that lists them all comparatively. However, there's nothign wrong with a little oil wight experimentation. If it doesn't work, swap it again.
Posted : 17/04/2009 7:16 am
