Fork noises
[Closed] Fork noises
X Fusion Sweeps about two years old. Started sounding a bit squishy so I did a lowers service, new oil, new SKF seals (green if it matters) and foam rings, all from J-Tech so I assume decent enough even though not the XF N-Volve or whatever they are called seals. Correct quantity of oil put back in. Now when I lift the front wheel there is an 'air moving' kind of noise as the sag extends, and the squishy noise is still there when I bounce them hard. What's going on?
Posted : 17/07/2016 6:36 pm
Ahem...
Posted : 17/07/2016 8:13 pm
I get similar on my Pikes when the rebound is on slow
Posted : 18/07/2016 4:40 pm
As hainman alluded to it could be the damper.
Changing the oil in that should be ok I did my slant fork and don't remember any dramas.
[url= http://forums.mtbr.com/shocks-suspension/official-xfusion-rl2-fork-service-tuning-thread-910996.html ]MTBR RL2 thread[/url] has pictures and all the technical detail you need.
Posted : 18/07/2016 4:52 pm
Thanks, I'll try that then. Just did the lowers and never went near the damper.
Posted : 18/07/2016 5:32 pm
