Fork mount repair s...
[Closed] Fork mount repair stand - anyone use one?
[#5614888]
With dropper posts being repair stand un-friendly, and more frames being carbon so not wanting to clamp the frame with a normal repair stand, it looks like a fork / rear drop out style repair stand might be a good idea.
[url= http://feedbacksports.com/shop/Sprint-Work-Stand-P74.aspx ]The feedback sports one[/url] looks like it will do the job quite nicely.
Any opinions?
Posted : 18/10/2013 3:25 pm
Never had a problem with a dropper post tbh, just push it up a bit if need be.
Posted : 18/10/2013 3:31 pm
I bought one of these for the same reason, funny tube shapes and a dropper post.
[url= http://www.topeak.com/products/Repair-Stands/prepstandrace ]http://www.topeak.com/products/Repair-Stands/prepstandrace[/url]
It's been fine - the only problem I have had is with my new FS bike is that the bar that the fork holder sits on isn't long enough so the slider bit is off the end. I just use a velcro strap to hold the fork crown on the bar itself and it's pretty stable. All my other bikes are fine and mounting the rear drop outs int he clamp not the fork is ok too.
Posted : 18/10/2013 3:32 pm
Northwind - Member
yup, absolutely fine as long as you clamp the lower section
Posted : 18/10/2013 3:35 pm
How tight are you clamping to have to worry about crushing your frame?
I don't tend to clamp the post on any of my bikes to work on them. Normally the top or seat tube and seldom very tight.
If it's a quick job I might just hang the bike by the nose of the saddle...
Posted : 18/10/2013 3:39 pm
[i] worry about crushing your frame[/i]
the clamp on my old stand wouldn't fit around the tubes on several of my bikes and I didn;t fancy clamping on the slidey bit of the dropper posts.
Posted : 18/10/2013 3:41 pm
I don't have a work stand at the moment, and thinking about getting one. I'm just over analysing (as usual) and thinking about carbon frames.
I'm not sure I'd have enough slack in the dropper remote to slide it out of the frame to hang it anyway so I'd have to disconnect it (Ks lev post).
So, it seemed like a fork mount stand made sense as it's obviously really easy to drop the front wheel out.
Posted : 18/10/2013 3:46 pm
