Fork choices?
[Closed] Fork choices?
Need some new forks for my old `05 Kona Dawg to replace the worn out Float RLTs.
Liking both of these;
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=54611 ]Sektor. would need to fit heavier spring[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=68493 ]DT Swiss. Same length as Floats[/url]
Choices, choices ๐Ÿ™„
What to do โ“ ๐Ÿ’ก
Posted : 18/02/2012 5:39 am
I have the 150 version of the Swiss and very nice it is. I've also got a Fox float and can't tell much of a difference. Go for it, looks great on a black frame too.
Posted : 18/02/2012 7:17 am
of any use to you...
[url= http://singletrackworld.com/forum/topic/fs-fox-vanillas-rs-sids-road-shoes-saddle-mechs-etc ]LINKY[/url]
Posted : 18/02/2012 7:21 am
I have the dts on my Pace - I love 'em. Have no experience of Sektors so can't say how they compare tho...
Posted : 18/02/2012 7:50 am
I have those exact DTs on my 2010 Dawg Supreme. They're cracking. ๐Ÿ˜€
Posted : 18/02/2012 11:28 am
Whatr are pace like to service. Can you service them yourself or do they have to be sent away?
Posted : 18/02/2012 1:02 pm
Cheers Jamie. Probabably going to stick with qr style to save buying a new wheel, got loads of other stuff to replace!!
Maint and servicing of the DT is the only issue as per lipseal โ“
Posted : 18/02/2012 1:35 pm
I'd be tempted to wait a bit longer and get a new hub. 15mm (or 20mm) is much stiffer / nicer - it's not a trivial upgrade at all, and if you're splashing out on new forks it's not much extra.
I've heard good things about the DTs - the only issue is the servicing which is a longer intervals but I'm not sure whether it's a home job. There are some videos on the DT website which show the process - decide for yourself whether it's something you can do. Otherwise it's perhaps worth getting the Rockshox which are a doodle to service.
Posted : 18/02/2012 5:00 pm
Found this....
[url=
SWISS SERVICE[/url]
...so I've pulled the trigger on some Dt Swiss 8)
Posted : 18/02/2012 5:02 pm
Looks like a bad link.. ๐Ÿ˜ฅ
Posted : 18/02/2012 5:10 pm
[url= http://bit.ly/y5AeTy ]Link[/url]
Posted : 18/02/2012 5:37 pm
